body lift
ive been dying to get a lift kit but i always see them for like 500-1000 but on ebay i found a body lift kit for 114 dollars...can any1 tell me why its so cheap? is it hard to do it yourself??? please help because im very interested in getting a lift so i can fit 31 inch tires or bigger if possible thank you and any feedback is appreciated..also if you have ideas or any other advice im open to it
[/align]
Just make sure the $114 kit is for your year and actually a BL. Make sure the kit is complete with front bumper raising brackets also. $114 isn't really that much. Synergy Offroad sells a BL kit for your year for $125.
a body lift isnt that bad to do. just get a couple friends over and it wont take that long. you are doing just what it sounds like, lifting the body. and yes you will be able to run a slightly larger tire. a good kit will come with detailed instructions. good luckwith the lift.
with a body lift you are only going to get 2", but you should be able to run 31x10.5x15's on stock rims.. if they rub you could just tweak your t-bars .5" or so and they should fit without rubbing.
