body lift
I wanna get a body lift for my 2 door blazer so I can fit 31s? Would my stock gears be enought sence I'm gonna put a e-fan on it and cool air intake?
Should be fine, but the Speedo will be off a little..
What gears do you have? They all should handle it fine, but 3.73s will be a lot better than 3.08s.
I wouldn't expect much from the fan and intake. The factory intake is a cold air intake. Look where it pulls air from. And the e fan puts more strain on the charging system, making the alternator work harder, and thus more power is needed to turn it. |
I forget the p code but ABS will kick a code at 10% vehicle to wheel speed error.
How much will my mpg be effected with 31s if I'm getting 17 right now?
You might get 15-16 with an average of 17 now
I have a 2 inch body lift with 31s and my mileage has decreased by 1 mpg
Originally Posted by cleburne red
(Post 584882)
Wait, Bigger tires roll farther with one rotation, how do you get worse mileage? Especially on the highway
Bigger tires will carry you further in one rotation but also bigger tires also weigh more & cause more rolling friction plus the increased height means more wind resistance. & mine only dropped one mpg and with 3.73 gears my speedo was 5mph at 60 I was really doing 65mph
