Suspension Tech Have a question about modifying your suspension? Ask it here.
Body mount - Help
Old Jul 2, 2012 | 08:40 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Default Body mount - Help
So today i was screwing around and taking off the rear body mount bushings and here is my problem.
Old Jul 2, 2012 | 08:46 PM
So for the big *** hole i the only thing i can think of is to make a plate of metal with a hole drilled out for the bolt for when i install the body lift. that will just sit on top of the frame where it rotted out
Old Jul 2, 2012 | 09:17 PM
warthogdriver's Avatar
that was my first thought when i saw the frame rot. i dont see why it wouldnt work...your gonna have them welded in place?
Old Jul 2, 2012 | 09:24 PM
yeah ill just tack weld them in
Old Jul 2, 2012 | 09:41 PM
maybe someone else will comment....like i said, i would have thought of something similar.
Old Jul 2, 2012 | 10:56 PM
i hope so
Old Jul 2, 2012 | 11:24 PM
Rottidog's Avatar
Replacement is the only option IMO. I'd look at getting some channel in the dimensions you need or getting some 3/16" or 1/4" broke (bent) to the size you need. Replacing the entire piece would be the best course of action because the rest of the steel is getting fugly as well. Why go through all that for the other metal to fail a year down the road?
Plus you'll have to grind off all the rust to get good welds & who knows how much base metal will be left to make a secure mounting point.
A lot of trade schools will do that for free & a donation to the student etc or some metal fab shops as well. If you don't have the material expect to pay for it but it should be under $10 for it & w/e they want to charge to form it on the brake. Measure everything up & start calling around with the stats.
EDIT <Jared made BF Veteran now! WTG man>
Old Jul 2, 2012 | 11:47 PM
+1 what rottidog said.
def try a trade school if you dont have the tools or know how...great way to save some cash. also i agree on maybe some steel options, a segment of square tube might be an option as well.
thanks for the congrats on the promotion...didnt even see that.
looks like your not to far behind me.
Old Jul 30, 2012 | 03:36 PM
USMC3782's Avatar
USMC3782 is on a distinguished road
Just wondering, where are you going to be ordering your new body mounts? I have to do all of mine and I was thinking of going with energy suspension poly. drivewire.com looks like they have the entire kit for less than $90.
Old Jul 30, 2012 | 09:13 PM
abig84's Avatar
nice. ive had similar issues in the past but i dont think that bad. i had some gigantic washers that fit perfectly in there, i just welded them in and was done with it
