Brake Upgrade on 1997 Blazer
My daughter's '97 4 dr Blazer is a good vehicle but the brakes STINK. Even with good pads and rotors, you have to stand on them to stop the thing. My '99 Blazer stops shorter with much less pedal effort...I'm aware that Chevy upgraded the brakes with the 1998 model year, but it made a HUGE difference. The '97 needs help...immediately.
Is there a way to upgrade the front brakes on the '97 so they will be more effective? Do later years have larger rotors that might be used, or is there some other way to upgrade? I'm not worried about the rears because the fronts do most of the braking...but either I'm going to improve these brakes or trade the vehicle. BTDT experiences especially helpful...thanks. |
RE: Brake Upgrade on 1997 Blazer
I know that one common thing to do with the pickups is a swap to f-body brakes, but I do not know the details on that...
Anyway, I found out just how much the rear brakes actually do when mine were rusted beyond belief. Fixed them up and braking is much, MUCH better than it was before. So don't count out a malfunctioning or worn out rear brake setup causing overall brake performance issues. |
I'm not sure about the upgrades, but my 1997 4x4 4-door stops just fine. The rear brakes actually do a good bit of the braking on this vehicle..no not as much as the front brakes but probably around 30-35% of the stopping force is supplied by the rear brakes on a rear- drive sport utility. You should at least make sure the rear brakes are in good shape before you condem the vehicle. Also, is it possible that your vacuum brake booster is failing? I say this because you said
you have to stand on them to stop the thing |
Thanks guys, good points. And I DO wonder how the brake booster is doing. I can easily re-check the rear brakes, although I inspected them when rotating tires a month or so ago.
And yes, that's a Monza Spyder. The only car I ever bought new - in 1977. I ordered it in Silver with Black interior, 305-V8, 4-speed and Positrac. I also got the intermittent wipers and two-position driver's seat back. That car stayed in my family until about 2002, when I sold it to a gent in Seattle who was a Monza fanatic. I'm convinced that if I could have held onto it longer, it would have been worth $$$, but I just didn't have a place for it. That car was fast, but awfully nose-heavy. You just don't see any of them around any longer. |
