Cant get shackle bolts out!
I tried to install lift shackes today. I got the nuts off the end of bothbolts that hold thepassanger side shackle on. I twisted and hammered and put more or less pressure on the springs and could not get the bolts out. I guess they are stuck in the rubber bushings. I sprayed them down with PB blaster and will keep spraying them this week and try again next weekend. Any other suggestions?
PS: I took off the add-a-leafs. WOW rides like a Cadillac compared to before. Shackles are the way to go! |
RE: Cant get shackle bolts out!
i had the same problem with my chevy. the bolts get seized to the metal sleeves in the bushings. i ended up using a oxy-acetylene torch to cut the bolts off and got new bushings.
and this is why i haven't made a set of shackles yet lol |
Best bet imo would be to buy new bushings and heat em' up and knock them out like stevelknievel said. Although your probably gonna end up having to use the good ole torch to heat them up and knock em' out. I have had to do this before and ended uptorchin' the bushings though but none the less got em' out.
Edit BTW make sure you have a fire extingusher close by. |
ORIGINAL: 99 Blazer 4x4 Best bet imo would be to buy new bushings and heat em' up and knock them out like stevelknievel said. Although your probably gonna end up having to use the good ole torch to heat them up and knock em' out. I have had to do this before and ended uptorchin' the bushings though but none the less got em' out. Edit BTW make sure you have a fire extingusher close by. and i agree make sure theres a fire extinguisher around haha i caught my garbage can on fire lol |
I just used a drill to get the old bolt/bushing out. I just drilled around the outside of the bushing and then took a hammer and knocked it out. took no longer than 10mins.
Hahaha, Miller I just realized from your CarDomain page that you took the 'R' off of Blazer on your emblem.
ORIGINAL: TripleBlackBlazer Hahaha, Miller I just realized from your CarDomain page that you took the 'R' off of Blazer on your emblem. |
yea were the "r" was taken off thats pretty cool nice ride by the way its pretty sweet thats a nice lift on it.
ORIGINAL: thegr81 yea were the "r" was taken off thats pretty cool nice ride by the way its pretty sweet thats a nice lift on it. |
i bit on your emblems i took my r's off of mine i think it looks pretty cool now and my friends who have blazer's are going to do it i think its going to be trend now just like toyota's were people take off the ota part to just say toy
