different spindles for Xtreme???
I heard that if I needed to lower my 2001 xtreme 2" in the front, the spindles that would fit a s-10 blazer wouldnt fit my truck. Where can I get some then? Also, I have 20" rims, so would i need to do any mods?
Yep. Blazers have sealed hubs so the spindles are not the same. Belltech makes a drop spindle for our rides.
Part number is 2102
They are pretty expensive. Most expensive part of the drop.
http://store.summitracing.com/partde...5&autoview=sku
http://www.stylinconcepts.com/part.a.../categoryid/30
Ignore the pictures, they are wrong.
20's should be OK if you keep the overall diameter the same as or smaller than the original diameter. I have 18's and with my tires I still have the stock overall diameter. I did not want my speedometer all messed up.
Only other thing I had to do was trim some of the front fender flares on the inside of the wheel well. I had to do it beacuse if I would turn sharp and hit a bump the tire would rub against the flare.
Part number is 2102
thereverendbill
Jun 19, 2010 10:12 PM
