Suspension Tech Have a question about modifying your suspension? Ask it here.
front end sags
Old Mar 27, 2010 | 10:37 AM
98jblaze's Avatar
98jblaze is an unknown quantity at this point
Default front end sags
hi just wanted to see what causes the front endof my 1998 blazer lt to sag besides the shocks going bad i have parked next to other blazers and my front end is lower because help thanks
Old Mar 27, 2010 | 12:17 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
i would think a simple adjustment to the t-bars will level it out.
Old Mar 27, 2010 | 01:42 PM
98jblaze's Avatar
Default front sags
yes i really don't want to do that don't want to ruin the front end parts but the back does sit alot higher then the front just picked up new shocks the gaberial max controls $59.00 a piece hope that brings it up some
Old Apr 13, 2010 | 09:36 AM
TommySkillz's Avatar
TommySkillz is on a distinguished road
i agree
Old Jun 1, 2010 | 08:46 PM
stereodesigner's Avatar
stereodesigner is on a distinguished road
They
Sell Coil Spacers if you have coils up front that will help the sag
Old Jun 1, 2010 | 09:43 PM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
His truck doesn't have coil springs. Idk about 1st gen s10 blazers but 2nd gen came with shocks and t-bars in the front, and leaf springs and shocks in the back.
Have your t-bars adjusted by a mechanic to set it back to stock height if the shocks don't fix it.
Old Jun 1, 2010 | 10:07 PM
Considering that no where in this thread does the OP state that he has a 4wd, the recommendation is somewhat valid. All 2wd s-series trucks came with coil springs in the front.
I had to dig back through numerous posts to determine what the OP had, drivetrain wise.
But since the OP has a 4wd, the options are to crank the t-bars (easy and practically free) or replace the t-bars if they are found to be weak. The suspension should be adjusted per the information in the Tech Article (DIY) Index.
doktornasty
Nov 3, 2013 03:12 AM
mkm1387
May 7, 2012 12:47 PM
BLAZER97LS
Apr 16, 2012 02:56 PM
tjmicsak
Jan 6, 2011 10:42 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
