Suspension Tech Have a question about modifying your suspension? Ask it here.
HELP!!!
Old Aug 6, 2007 | 05:23 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
Default HELP!!!
i need to know if there would be anything i need to mod if i got a 3" BL, such as brake lines anddrive shaftlinkage, ect?
Old Aug 8, 2007 | 12:16 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: HELP!!!
get on the manufacturers website and download the install instructions... it should answer the install questions
Old Aug 8, 2007 | 12:20 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default RE: HELP!!!
i just did a 2" on my 97 (couldnt find a 3 inch) and besides the fan shroud, oil filter and bracket, and bumpers i didnt have any issues with anything. but its a good idea to have a buddy stand around and make sure nothings getting yanked
Old Aug 10, 2007 | 05:41 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default RE: HELP!!!
Same here, no problems other than the above mentioned. Also I don't think they sell a 3" for a 97. I could only find a 2"
Old Aug 10, 2007 | 05:50 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: HELP!!!
Biggest thing is to check all your lines underneath and in the engine bay to make sure nothing stretches.....also make sure you watch you brake lines on the driver side. There should be one retainer on the shock tower and another further down along the frame right about under the firewall.
