Suspension Tech Have a question about modifying your suspension? Ask it here.
How to level vehicle after adding add-a-leaf to rear axle
Old Dec 26, 2008 | 12:43 AM
DaleA's Avatar
DaleA is an unknown quantity at this point
Default How to level vehicle after adding add-a-leaf to rear axle
I have a 2000 blazer. The rear end has been sagging for a few years due to pulling trailers and the "premium ride" soft spring. I put a pair of Rough Country add-a-leafs on and it solved my problem with the back end sagging when pulling our 5000 lb horse trailer or speed boat. However, the ride is a bit stiffer, more truck like than before, but that's fine. I actually like the way it feels now more than before.My problem is that the rear is now about 2 or more inches higher than the front. How can I raise the front end to level my vehicle? I have heard about raising the torsion bars but that might cause a problem with cv joints and ball joints (just had them replaced at 98000 miles). any suggestions? even with trailer hooked up it still is higher in the back. I do like the way the add-a-leafs do their job though. Wish i had done this long ago. Installation was actually not too difficult. I looked at the torsion bar adjusting bolts and noticed that the pass side bolt was out about 1/2 inch farther than drivers side, but the measurement from the lip of the fender well to the ground is 32 inches with lt235/75 r15 light truck bridgestone tires. Any suggestions on how high I can raise the torsion bars without hurting cv joints or ball joints? This might be my only avenue to solve this dilema.
Old Dec 26, 2008 | 09:03 AM
WolfPack's Avatar
Default RE: How to level vehicle after adding add-a-leaf to rear axle
the torsion bars are your front suspension, so the only way to lift up the front end to match the back is with a tbar crank. Do some reading on here (search) and decide if the pros outweigh the cons.
95blazerlt
Sep 21, 2013 10:44 PM
LucasMI
Jan 2, 2012 02:15 PM
99LS4x4ryanlw
Lifting Tech
Sep 29, 2011 02:13 PM
PaulO2288
Apr 21, 2011 12:25 AM
monette9999
Apr 29, 2010 06:06 AM
