Suspension Tech Have a question about modifying your suspension? Ask it here.
How and Where to go for a 3" drop at all four corners?
Old May 13, 2008 | 02:42 PM
BlazerChops's Avatar
BlazerChops is an unknown quantity at this point
Default How and Where to go for a 3" drop at all four corners?
As it says in the title, this is what I'm wanting to do eventually. Replacing/upgrading the shocks as well to cope with the lowered stance as well as front/rear sway bars. If I'm thinking of everything just for lowering, this should include...
Front:
Drop Spindles
Lowering Springs
Lowering Shocks
Rear:
Drop Shackles
Lowering Leaf Springs
Lowering Shocks
Where online does one go to buys this stuff? Also, what kind of good shops are out there to do this kind of work at decent prices with no BS?
Thanks!
Old May 14, 2008 | 11:34 AM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: How and Where to go for a 3" drop at all four corners?
just search, I bought my spindles from someone on here for $50(you will pay about $250 because they are dif. than the 83-97), rear leafs(make sure they are for a 2dr)from a guy on s10forum for $80 and blocks from advance auto for $20. I still need drop shocks but it handles great.
try stylintrucks.com, ebay.com, djmsuspention.com, streetbeatcustoms.com, etc.
Old May 14, 2008 | 07:10 PM
Well I've been looking on stylintrucks.com for a little bit here and it looks like I can get to a 3" drop pretty cheap. From what I gather, I can just buy 3" BellTech lowering springs for the front, 3" BellTech lowering blocks for the rear (keeping the stock springs) and Belltech Nitro Drop 2 shocks all the way around. That's just $370 for a 3" drop!
Am I right about this setup?
Also, I still can't seem to find anything about anti-sway bars...
Old May 14, 2008 | 10:58 PM
blazin97's Avatar
they sway bars will be almost parallel to the truck with it lowered 3". you will have to either get shorter endlinks or use regular bolts.
$370 for 3" with shocks aint bad. but dont forget to get an alighnment done right after you drop it otherwaysyou will have bad alighnment issues along with wear through tires QUICK.
Fourstar200
Dec 28, 2011 12:41 AM
jhoe414
Oct 12, 2008 11:28 AM
2001blazer
Jan 30, 2006 10:13 PM
2000WhiteZR2
Jul 26, 2005 09:20 PM
Blaize70
Dec 24, 2004 02:25 AM
