Suspension Tech Have a question about modifying your suspension? Ask it here.
idler arm
Old Sep 23, 2005 | 10:47 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default idler arm
how easy or hard is it to replace the idler arm? i went to get my oil changed and they informed me that my cv shafts are shot and so is my idler arm and estimated a grands worth of parks and labor.... im sayin forget the cv shafts for now dont really need them. but the idler arm is the reason my truck favors the left side... so any info would be appreciated thanx
p.s they quoted me 188 for the idler arm and 98 for the labor....
Old Sep 24, 2005 | 01:17 AM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: idler arm
if its like my 2wd s10 its about a 1/2 hr job and only 3 bolts. 2 bolts on the frame and one on the front suspention. I would look at it and see it its that hard. its on the pass. side on the frame.
Old Sep 24, 2005 | 01:44 AM
mines is 4x4 im gunna take a look tomorrow
Old Sep 25, 2005 | 03:26 AM
Hanr3's Avatar
Shouldn't be that hard, and he's right only a few bolts.
Old Sep 25, 2005 | 04:04 AM
chevylane2003's Avatar
chevylane2003 is an unknown quantity at this point
you may need a small press to get the arms seperated though
Old Sep 25, 2005 | 10:58 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Ok Timey, the AutoZone spokesperson has something to say:
*Clears throat* You can get an idler arm with a lifetime warranty at AutoZone for $21.99.
$188? WTF are they smoking?
Old Sep 25, 2005 | 02:44 PM
ha ha ha ha
Old Sep 25, 2005 | 04:26 PM
blazin97's Avatar
thats what I was thinking. I just replaced mine and it was $26 at Zone. and I just looked at my 4x4 blazer its the same as the s10, and the 2wd 97 blazer(my parents have) is the same. 2 18 mm(I think, you need a socket, extention and wrench) bolts on the frame and one on the stearing sh*t, the one stud after getting the bolt off is hard to seperate, I used a pitman arm puller I had sitting around. It is really easy.
Old Sep 26, 2005 | 12:52 AM
blazin97, unless I'm mistaken (which does happen frequently), the idler arm is on the drivers side and the pitman arm is on the passenger side. I believe we may be talking about 2 different things here...
Old Sep 26, 2005 | 01:14 AM
lol thanx for the help guys.... this pitman arm puller you use is it expensive or do you think i could rent it from auto zone?
