Suspension Tech Have a question about modifying your suspension? Ask it here.
Lift kit help
Old Dec 30, 2005 | 06:20 PM
Autoidiot's Avatar
Autoidiot is an unknown quantity at this point
Default Lift kit help
I have a 98 jimmy 4x4 SLT. I am wanting to raise it enough to get 30" Buckshot mudders on it. How many inch's should I raise it and should I use a body or suspension lift.
i
Old Dec 30, 2005 | 10:41 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Lift kit help
i have 30x9.5" tires on my '95 with no lift and no rubbing.
https://blazerforum.com/upfiles/39/a...y760118085.jpg
Old Jan 2, 2006 | 01:40 AM
Hanr3's Avatar
I have BFG All-Terrains 30/9.5R15 on my '00 and have had them on my '87. Both 4x4 S10-Blazers and they didn't rub on either truck.
Old Jan 2, 2006 | 10:03 AM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
I would think some mudders would probably end up rubbing a little bit, maybe not. Mudders will be a little more beefy than the all-terrains. It would be worth a shot with no lift but if they rub a little bit a 2 inch body lift should cure that.
Old Jan 2, 2006 | 10:17 AM
RedBlaze's Avatar
Oh yeah if you are going to try the 30" with no lift first you will need to use the stock rims. Dont know if you were planning on using them or not.
bigdaddykane93
Feb 24, 2013 02:30 PM
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
jjsmith1228
Oct 31, 2010 03:56 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
bossxhog
Suspension Tech
Jan 6, 2010 01:27 PM
