Suspension Tech Have a question about modifying your suspension? Ask it here.
Need to stop body roll!!!!!!!!!!!!!!!!!!
Old Nov 20, 2008 | 10:15 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Default RE: Need to stop body roll!!!!!!!!!!!!!!!!!!
Best thing you can change are the shocks and Energy Suspension Sway Bar Bushings... Mine is sporting Monroe Sensatracs right now.
Shocks are easy but here are the numbers and homework for the bushings - PLEASE verify that this is what you need in diameter!!!
Part Number:
3.5207R - Front 33mm 4x4 with End Link = $39.99
9.5159R - Rear 23mm Mount Set = $19.99
9.8015R - Rear 3/8 End Link Bushings = 8.99
* Part Number 9.8015R is a Universal Kit and it has 8 Washers and 8 Bushings in it - you`ll only need 4 of them.
* Part Number 9.5159R is the Rear 23mm Mount and is a very tight fit... Use a vise anddrillor drill press to open the mounting hole up 1/16th".
I bought all of them all through my local Advanced Auto Parts.
What prompted the swapping..? I had a power steering pump fail and it ate up the driver`s side bushing at the frame. That, and 95% of my commute is highway.
Best thing I ever did on the truck. And you can sure see these puppies walking up to the truck too!
Took me about two hours to remove clean and get everythign done.
I also had enough bushings left over from the one`sI didn't needtocreate this custom Hi-Lift Jack Mount!
Enjoy the pics!
P.S. Thant`s not Anti-Freeze dripping - It`s degreaser from the local car wash!
Old Nov 23, 2008 | 11:34 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
ive noticed that my blazer lumbers like its bigger than it actually is.
Old Dec 8, 2008 | 09:22 PM
thegr81's Avatar
Unlike you lifted folks, my fix for body roll was to go lower to the earth LOL handles like a sports car I tell ya!!!
Old Dec 29, 2008 | 02:04 PM
hubbmatt's Avatar
hubbmatt is an unknown quantity at this point
(Energy Suspension kit Part # 33119) This will fit on a 96 right???
Old Jan 30, 2009 | 09:13 PM
ORIGINAL: hubbmatt
Check with Jegs or Summit for a part number, and then hit the local guys - In my case, advanced was less money by more than a couple of dollars!
dannyb91979
Jul 16, 2013 06:08 PM
blazer74
May 1, 2012 08:42 PM
bryanmine
May 19, 2011 11:27 AM
PHATSPEED7x
Sep 18, 2009 06:06 AM
86S10
Mar 12, 2008 06:01 PM
