Suspension Tech Have a question about modifying your suspension? Ask it here.
Quick lift question
Old Mar 24, 2008 | 09:06 PM
GimmieBoost's Avatar
GimmieBoost is an unknown quantity at this point
Default Quick lift question
I did a search and didn't come up with a definite answer. I have a '94 Blazer 4x4 and of course I want a little lift. I'm REALLY wanting to clear 32s and not have to worry about them rubbing unless I do something really stupid. I was wondering if it could be done with a 2" RC lift, 3" body lift, and 2WD wheels. I'd rather stay away from doing any trimming if possible.
Or would I be better off with a 2+2 lift and 31s? Any help will be appreciated.
-Jesse
Old Mar 24, 2008 | 10:26 PM
WolfPack's Avatar
Default RE: Quick lift question
Probably will be ok running 32's..but not sure. If you're modifying enough to put on 32s...why so afraid to trim if needed? From what I've seen, if you stick your wheel out wider (2wd rim), you'll rub on the body and need to trim or lift more (hopefully the 5' total lift will fix that though), or if you stay with stock rims or at least stock backspace, you'll rub on the frame. Hard call!
Old Mar 25, 2008 | 12:12 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
go 2+2 with a 5" backspaced wheel... maybe 4.5"... and 32's should not rub unless wheeling. If you plan on off-roading at all, or even going over speed bumps you will need to trim the fenders. With stock backspacing you will rub the frame at full lock.
Old Mar 25, 2008 | 02:40 PM
I definitely want to go offroading and not have to worry about rubbing. That's the only reason I'm lifting it. So with a 2+2, 5" backspaced wheel, and 31s I should be in the clear, right?
Thanks,
Jesse
Old Apr 5, 2008 | 12:48 AM
I decided not to go with the RC lift and instead peice together my own stuff. I got some 2" shackles on the way and I'm searching for shocks. Do I need to find shocks that are made for a little bit of lift or will stock height ones work?
Old Apr 5, 2008 | 02:26 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
stock will work just fine.
dj00140
Mar 2, 2011 08:52 AM
Oleyella
Lifting Tech
Nov 1, 2009 06:15 PM
89K5
Nov 16, 2007 05:26 AM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
black19
Jul 2, 2006 11:58 PM
