Suspension Tech Have a question about modifying your suspension? Ask it here.
rear end
Old Jul 21, 2013 | 07:41 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default rear end
Craigslist: S-10 7.5 3:73 Rear http://wilmington.craigslist.org/pts/3950674525.html
will this fit my 2001 s10 blazer 2wd?
Old Jul 21, 2013 | 11:55 PM
Twip's Avatar
yeah it should fit. its from a 2wd s10 pick up, but its going into a 2wd blazer. it should be fine. you should measure it just to make sure. you will want to measure how far the spring perches are from the center and from wheel mounting point to wheel mounting point. then, if i were buying it, i would pull the cover off before installing it and changed the fluid and inspect the gears.
Old Jul 22, 2013 | 07:51 AM
Jamaroon's Avatar
It will be missing the sway bar mounts. Blazers have a rear sway bar, pick-ups don't.
Old Jul 22, 2013 | 08:57 AM
El_Beautor's Avatar
It will fit just fine, but it won't have the rubber bump stop cups on the spring perches. Not the end of the world unless you're overloading your Blazer, but just something to know. The sway bars mount using a U-bolt and in my experience they are not welded to the axle, so you should be able to transfer the mounts from the old axle to the new axle.
Old Jul 22, 2013 | 09:46 AM
Jamaroon's Avatar
Good to know, I've never bothered looking how it was attached. I just knew that the pick-ups don't have them.
Old Jul 23, 2013 | 10:39 AM
01blazer16's Avatar
Ok thanks
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
tammikm
Aug 18, 2006 11:07 PM
1xtrmblzr
Nov 11, 2005 03:12 PM
