Suspension Tech Have a question about modifying your suspension? Ask it here.
ROCK AND ROLE
Old Sep 13, 2006 | 06:49 PM
50andFlyFishing's Avatar
50andFlyFishing is an unknown quantity at this point
Default ROCK AND ROLE
EASYIST WAY TO WIDEN STANCE
Old Sep 13, 2006 | 06:53 PM
Kellen's Avatar
Kellen is an unknown quantity at this point
Default RE: ROCK AND ROLE
quick answer low backspace wheels
Old Sep 13, 2006 | 07:00 PM
how much diff would this make from stock
Old Sep 13, 2006 | 07:05 PM
nuderstand term back spacing but not the low what do you mean by low
first 4x4
Old Sep 13, 2006 | 07:11 PM
Kellen's Avatar
backspacing on the stock rim is 6 inches.
if you go with a 3.75 inch or 4.5 inch backspacing aftermarket rim they will stick out, giving the appearance of a wider stance.
Old Sep 13, 2006 | 07:12 PM
Kellen's Avatar
The wheels on this truck have 3.75 inch backspacing I believe
Old Sep 13, 2006 | 07:30 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Before you go getting new rims what size tires do you have on there? 30x9.5 I wouldn't change the backspace more than .75 if you got 235/75's you can probably go to about 4.5 back space if you have 235/70's you might be able to get away with 4 inches maybe 3.75. I know for a face 235/75's will rub if you go to 3.75 back spacing.
Old Sep 13, 2006 | 07:45 PM
Kellen's Avatar
I was just giving the short answer
I just ordered 15x8 rock crawlers with 4.5 inch backspacing and I'm putting on 30/9.5 tires. hope they dont rub too too bad[&:]
Old Sep 13, 2006 | 08:22 PM
tommyd's Avatar
If I had to guess they will rub if your at the stock ride height. But let me know if they work out for you because I would be buying some for myself if they dont rub
Old Sep 13, 2006 | 08:26 PM
Kellen's Avatar
Well I'm pretty sure they will rub at full lock, but I just wont turn the wheel that far
