Suspension Tech Have a question about modifying your suspension? Ask it here.
suspension and body worth it??
Old Dec 11, 2006 | 01:57 PM
crazyfry767's Avatar
crazyfry767 is an unknown quantity at this point
Default suspension and body worth it??
I have a 97 jimmy four door and for the summer im planning on getting the 5" trailmaster lift..I know you can run 32's with this but i was wondering if it would be worth it to gte the 2" BL along with it to clear 33's, I dont do that much off roading i just want the stance. Has anyone got and pics of a four door with a 5" lift and 32's?
Old Dec 11, 2006 | 02:00 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: suspension and body worth it??
If you're not going to wheel it hard, i'd just throw the 33's on with the 5" lift.
Old Dec 11, 2006 | 02:49 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
a few blazers5 inch trailmaster + 2 inch PA body lift
Old Dec 11, 2006 | 03:59 PM
Jigg's Avatar
That last one is Adam Bright's, it has the TM5", 2" BL and the 2" Superlift.
Old Dec 11, 2006 | 11:22 PM
would 33's fit with the 6" of backspacing and just the 5" suspension though? or is the BL a must have in order to do that?
Old Dec 12, 2006 | 03:08 PM
a_tack's Avatar
you would probably be okay with the 33's and just suspension if you arent doing alot of off-roading..
Old Dec 12, 2006 | 11:29 PM
yea like i said its just mostly for the stance...i mostyly just go mussing in the fields around here and drive on the beach, no real full out trails or anything, but i wish i could get a pic of this because i just don't like the look of a truck with the whole wheel well filled with tire, you know what i mean??
Old Dec 13, 2006 | 03:19 PM
blazinloud's Avatar
damn a_tack those are some beautiful blazers. I wish i knew more about lifting
any idea what a 5" lift would cost a guy.........where would i go, just to any suspension shop? if its under a g then i could prolly get er done this summer too. i would love to run some big swampers.
Old Dec 14, 2006 | 02:55 AM
the TM lift is on www.truckperformance.com for around 1100, thats where im picking mine up at but i have no idea how much to install...anyone gotta rough estimate??
Old Dec 14, 2006 | 05:00 AM
a_tack's Avatar
trailblazers in lexington, KY quotes suspension lifts cheaper than body lifts... but you are probably looking at anywhere from $400-$700 maybe?
