Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension lift
Old Sep 22, 2008 | 09:47 AM
blazin 4.3's Avatar
blazin 4.3 is an unknown quantity at this point
Default Suspension lift
hey i got a ? what is the cheapest way to raise my 98 blazer 4 door?? do i have to buy a key to tighten the torsion bars in the front??
Old Sep 22, 2008 | 10:31 AM
WolfPack's Avatar
Default RE: Suspension lift
no. the key is what actually what is moved by tightening the adjuster bolt, which increases the pre-load on the torsion bars, giving you front end lift. But there is alot more to consider than just 'woo hoo! turn a bolt and I get some lift!'
Check out the related threads below, and try some searches for suspension lift or torsion bar lift. You can do it the cheap way by tightening the bolts (~1.5' of lift) or you can buy new keys for $$ which will give you more lift. But again, searches will explain everything I assure you
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
