t bar crank how tight
hello first post here, My truck was sitting a little low on the passanger side with all new front end parts and shocks all around so coudint figure out why. I figured it must be the t bar so i researched and found out how to do it, jacked it up on level ground. I started to turn the bolt with the wrench it was very easy almost could be done by hand. So this is my question how much tension should i feel on the bolt as it seams way to easy
That is normal, once you have the wieght of the truck back on it, it will be harder to turn.
thanks was not sure now i can level it out thanks:):)
