Suspension Tech Have a question about modifying your suspension? Ask it here.
t bar crank how tight
Old Apr 28, 2009 | 07:58 PM
tonyhonsberger's Avatar
tonyhonsberger is on a distinguished road
Default t bar crank how tight
hello first post here, My truck was sitting a little low on the passanger side with all new front end parts and shocks all around so coudint figure out why. I figured it must be the t bar so i researched and found out how to do it, jacked it up on level ground. I started to turn the bolt with the wrench it was very easy almost could be done by hand. So this is my question how much tension should i feel on the bolt as it seams way to easy
Old Apr 28, 2009 | 09:09 PM
bandidolenny's Avatar
That is normal, once you have the wieght of the truck back on it, it will be harder to turn.
Old Apr 29, 2009 | 07:19 PM
thanks was not sure now i can level it out thanks
kickme005
Sep 9, 2010 03:11 AM
Jakester91119
Apr 3, 2009 01:11 PM
mojoe10k
Mar 6, 2009 12:55 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
LORCLAS
Apr 17, 2007 09:44 AM
