Suspension Tech Have a question about modifying your suspension? Ask it here.
Torsion Bar Crank....help
Old Aug 29, 2006 | 12:00 PM
Bgray's Avatar
Bgray is an unknown quantity at this point
Default Torsion Bar Crank....help
Hey guys. Now Im not all excitited to go ruining my cv's, balljoints, etc by cranking my torsion bars. I am just wondering, If I crank the torsion bars what problems can I expect to encounter after the fact? I know i will need an aligment, but what else will happen?
Also...What should I do to jack the back the few other inches?
thanks
[IMG]local://upfiles/1756/B0E808F82C65415E8CB99236AD68DE9E.jpg[/IMG]
Old Aug 29, 2006 | 03:24 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: Torsion Bar Crank....help
you can lessen the wear on the cv joints if you lower the front differential an inch or so if you cranked for 2--you can also grind down the droop stops a little on the a-arms to ease the topping out of the suspension, balljoints--upper balljoint can be flipped to the underside of the a-arm--that will save a bit of ball joint wear there---lower a arms there isnt much you can do other than getting a custom one made.....
anyone else?
oh and for the rear either got with shackles or re-arched springs
Old Sep 8, 2006 | 04:30 PM
96Blaze4.3's Avatar
96Blaze4.3 is an unknown quantity at this point
How do you lower front diff ???And to flip the balljoint , just take it off and put it upside down right?
Old Sep 8, 2006 | 04:49 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
Curious myself as I have the same truck and wanna do the same. I only want a couple inches front and back with no major money invested( Daily Driver)
Old Sep 8, 2006 | 08:12 PM
sledneck16's Avatar
yea the front differential isnt lowerable----well not easily---im scrapping that idea for my truck and just doing a 2' BL for now (my bars are cranked about 1.5") theres just more notching, welding and relocating than im willing to do right now.
as for the balljoints, do a search for replacing ball joints---but when you put the new one in put it in from the underside instead of from the top.
good luck and keep me updated on any ideas---I'm game for trying a few things myself
Old Sep 9, 2006 | 03:03 PM
96Blaze4.3's Avatar
I found a braket to lower the front diff once , but can't remember where I found them . Guess one could prob fabricate it
Old Sep 9, 2006 | 07:40 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
little off topic but I really like your hood. Where di you get it? i NEED one.
Old Sep 9, 2006 | 09:58 PM
sledneck16's Avatar
yea the only problem with lowering the front diff is that you would have to cut into the lower a-arm mount---and a few other suspension parts--not something im willing to do....yet
but if you can track down that bracket---im curious[8D]
Old Sep 10, 2006 | 04:45 PM
96Blaze4.3's Avatar
I will try to find it for you . Give me a few days as I have alot going on around here , but I will try my best to find it again.
a_tack
Lifting Tech
28
Dec 22, 2015 08:42 PM
CraigSnedeker
Lifting Tech
May 15, 2011 08:18 PM
Duram98jimmy4x4
Suspension Tech
Mar 19, 2011 07:18 PM
appstateblazer
Mar 4, 2010 09:39 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
