Suspension Tech Have a question about modifying your suspension? Ask it here.
Torsion Bar wont go up!
Old Jan 27, 2008 | 04:45 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default Torsion Bar wont go up!
I cranked the right side of the T-bar about 4 full turns and it only raised the front 1/2 inch...
it is almost cranked fully, and it just now is level with the left side!
It something wrong here? Right side is cranked almost all the way, and the left side I havent touched and there level...
Old Jan 27, 2008 | 05:03 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Torsion Bar wont go up!
You could have a sagging right torsion bar. Also if the truck was level before then, something is definately wrong, unless the left torision bar had been cranked before you bought the truck or something.
Old Jan 27, 2008 | 05:14 PM
Zasder's Avatar
Nope they were exactly the same, but the right was 1/2 inch lower....
now I cranked the right T-bar what shoulda gave me 2 inchs and it only gave me 1/2 inch
Now they are level
Old Jan 27, 2008 | 07:29 PM
Sounds like a sagging bar.
Old Jan 27, 2008 | 07:31 PM
Zasder's Avatar
Is that an easy fix? to replace both the torsion bars?
Old Jan 27, 2008 | 07:32 PM
TripleBlackBlazer's Avatar
I actually cranked mine to level out the front from side to side. Cranked the driver's side down 5 turns and passenger's side up 5 turns. Measurement from tire to center of wheelwell on both sides was even after that. Any remedies for sagging bars?
Old Jan 27, 2008 | 08:05 PM
Only remedy is to replace the bars. Both of them.
Old Jan 27, 2008 | 08:07 PM
Zasder's Avatar
How much does that run?
Difficulty 1-10?
Edit:
They are covered under warrenty
Does having a sagging front end give me reason for having them replaced? or do they have to break for them to be covered?
Old Jan 27, 2008 | 08:08 PM
willjones's Avatar
Is it an at home job?
Old Jan 27, 2008 | 08:12 PM
Zasder's Avatar
I have access to a shop with unlimited tools
