what will it take 2 tuck 31"x10.50
i gotta stock 95 blazer 4x4 2 dr non zr2, i wann put 31 x 10.50's on it. what will it take? i plan on buying some cheap wagon wheels so rim size/bs can vary. do i need a lift? 3" body lift maybe?
RE: what will it take 2 tuck 31"x10.50
Use the search feature...please...
You need at least 2 full inches of lift. Cranking the tbars up usually does not give you 2 full inches. If you add in new rims with anything less than the 6' of stock backspacing, you're going to rub alot more...or need more lift. I've got 1.5' tbar and 2' BL and still catch fender every once in a while because of my rims 4.5' backspacing. |
if fit them with my stock wheels with about an inch of tb lift and 2" AAL's in the back. but they are worn so im not sure about new ones since im very close to the fenders when turning. I also rub on the on the frame very slightly
