Suspension Tech Have a question about modifying your suspension? Ask it here.
what will it take 2 tuck 31"x10.50
Old Aug 24, 2008 | 02:05 PM
robbiegamble's Avatar
robbiegamble is an unknown quantity at this point
Default what will it take 2 tuck 31"x10.50
i gotta stock 95 blazer 4x4 2 dr non zr2, i wann put 31 x 10.50's on it. what will it take? i plan on buying some cheap wagon wheels so rim size/bs can vary. do i need a lift? 3" body lift maybe?
Old Aug 24, 2008 | 02:42 PM
WolfPack's Avatar
Default RE: what will it take 2 tuck 31"x10.50
Use the search feature...please...
You need at least 2 full inches of lift. Cranking the tbars up usually does not give you 2 full inches. If you add in new rims with anything less than the 6' of stock backspacing, you're going to rub alot more...or need more lift. I've got 1.5' tbar and 2' BL and still catch fender every once in a while because of my rims 4.5' backspacing.
Old Aug 24, 2008 | 09:42 PM
NVANZEE's Avatar
if fit them with my stock wheels with about an inch of tb lift and 2" AAL's in the back. but they are worn so im not sure about new ones since im very close to the fenders when turning. I also rub on the on the frame very slightly
onebadblazer29
Tires and Wheels
Dec 30, 2011 12:38 PM
steve0o09
Tires and Wheels
Jun 15, 2010 03:54 PM
bornla
Nov 28, 2009 11:55 AM
ivannj
Jan 6, 2006 01:12 AM
