01 blazer zr2 running 35s
Old Mar 31, 2018 | 07:55 PM
eddy815's Avatar
eddy815 is on a distinguished road
Default 01 blazer zr2 running 35s
I have a 2001 blazer zr2 mostly stock running the stock size 31 inch tires .. I'm planning a build up this summer and was planning on going with 3 inch lift shackles and 1.5 inch tbar crank along with a 2 or 3 inch body lift would I fit 35s or should I just stick with 33s .. I don't mind trimming fenders and I'm hoping to build a bumper .. just looking for opinions .. not looking to be told about parts wearing out or weak front ends .. I already know .. not gunna be doing major offroading.. mostly gunna be a winter beater and mild trail/back roads
Old Apr 1, 2018 | 06:20 PM
AJBert's Avatar
Plan on the 33's. To fit 35's you'll need at least a 6" lift and even then you may need some trimming.
Old Apr 2, 2018 | 05:13 PM
eddy815's Avatar
Ok thanks .. Still debating on a SAS with xj Cherokee axles seems pretty straight forward and I can weld so that's a option
Old May 2, 2018 | 12:08 AM
Nadamamasboy's Avatar
Nadamamasboy is on a distinguished road
You also want to be careful with the T bar crank. I had a full size Ram that I did that too and it absolutely ruined the handling. Probably fine for off road only build but I don’t recommend it; totally changes your front end geometry
Old May 2, 2018 | 12:28 PM
chevyriders's Avatar
I like the sas idea...but I'm biased lol
Old May 2, 2018 | 08:32 PM
This.
bigred01
Tires and Wheels
May 4, 2013 09:56 PM
atvwarrior
Apr 22, 2012 03:48 PM
burko
Jun 17, 2011 06:40 PM
8five-k5
Nov 10, 2010 01:00 PM
sinned
Lifting Tech
Jul 31, 2008 12:06 AM
