02 SS Camaro wheel on 2wd 2000 Jimmy
Has anybody put 02 SS Camro wheel on a 2000 2wd Jimmy or Blazer? I'm new to the mini truck world and would like to find out what spacers to run.
I put them on my 4WD 2dr and they sit nearly flush with the fender in the front and about 1-2" sunken in, in the rear.
I've seen them on a 2WD S10 on S10forum, but unsure of what spacers he used, if any. |
Sounds good. Thanks
Camaro SS wheels - S-10 Forum
Looks like 2.25" minimum spacer but 2.5" will work, too. I love the wheels, they look incredible. If you can find the machined face with black insert rims from the same time frame (2000-2002) for a good price, I'd go with them. I believe they are an anniversary rim, 35th maybe? http://img339.imageshack.us/img339/2142/cimg8015pb7.jpg |
Is that all the way around? I'll half to check those out.
The rear track is a little narrower than the front so you may want to do 2.25" in the front and 2.5-3" in the rear but it's really best to test yourself once you have the rims to see what you'll need and/or want.
im thinking about buying some 17 in camaro ss wheels for my 2002 blazer 2wd , and i dont know how they will fit . can i get some advice on spacers or if i even have to run them. i found a full set for 100 and i want to jump on them before there sold
Same size spacers as TBB mentioned. Backspacing is the same.
