02 SS Camaro wheel on 2wd 2000 Jimmy
Old May 22, 2012 | 06:16 PM
5093jd's Avatar
5093jd is on a distinguished road
Default 02 SS Camaro wheel on 2wd 2000 Jimmy
Has anybody put 02 SS Camro wheel on a 2000 2wd Jimmy or Blazer? I'm new to the mini truck world and would like to find out what spacers to run.
Old May 22, 2012 | 06:50 PM
TripleBlackBlazer's Avatar
I put them on my 4WD 2dr and they sit nearly flush with the fender in the front and about 1-2" sunken in, in the rear.
I've seen them on a 2WD S10 on S10forum, but unsure of what spacers he used, if any.
Old May 22, 2012 | 07:18 PM
5093jd's Avatar
Sounds good. Thanks
Old May 22, 2012 | 07:51 PM
Camaro SS wheels - S-10 Forum
Looks like 2.25" minimum spacer but 2.5" will work, too.
I love the wheels, they look incredible. If you can find the machined face with black insert rims from the same time frame (2000-2002) for a good price, I'd go with them. I believe they are an anniversary rim, 35th maybe?
Old May 22, 2012 | 09:47 PM
5093jd's Avatar
Is that all the way around? I'll half to check those out.
Old May 22, 2012 | 10:10 PM
The rear track is a little narrower than the front so you may want to do 2.25" in the front and 2.5-3" in the rear but it's really best to test yourself once you have the rims to see what you'll need and/or want.
Old Jan 20, 2013 | 08:20 PM
billyw88's Avatar
billyw88 is on a distinguished road
im thinking about buying some 17 in camaro ss wheels for my 2002 blazer 2wd , and i dont know how they will fit . can i get some advice on spacers or if i even have to run them. i found a full set for 100 and i want to jump on them before there sold
Old Jan 22, 2013 | 10:24 PM
AJBert's Avatar
Same size spacers as TBB mentioned. Backspacing is the same.
Az_S15
Tires and Wheels
Jul 16, 2013 03:29 PM
jeffbeckib
Tires and Wheels
Apr 13, 2011 03:46 PM
Zane25-hitch
Jan 17, 2010 12:07 AM
