15"x7" with 4" backspacing on 4x4 S10
Old Oct 1, 2010 | 05:25 PM
S.Hafsmo's Avatar
S.Hafsmo is on a distinguished road
Default 15"x7" with 4" backspacing on 4x4 S10
Like everybody else I'm looking for new wheels for my 1994 Blazer S10 4x4, and I have found some Rock Crawler series 99 15x7 4"BS, but from what I've read nobody seems to think these will fitt without rubbing in the front?
Everybody just replys: "You might have some rubbing"
Isn't there anybody on this forum running with lower ET rims then the stock ET+60mm (6"BS) on a stock car? (no lift, no cut-outs)
I'm gonna use the stock 235/70/15
Old Oct 1, 2010 | 10:53 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
You should be ok if you use the stock size tire and don't do any hard wheelin or curb jumpin. I had the same size, style and offset wheels on mine with 31s with a t-bar crank and shackles, but I rubbed so I took a sawzall and a big hammer and did some friendly persuasion lol
Old Oct 2, 2010 | 04:40 AM
S.Hafsmo's Avatar
Thanks, then i'll just order the rims and well se how it fits.
Others are welcome to share their experiances with low ET wheels. (pics are welcome as well)
Old Oct 2, 2010 | 01:11 PM
wills-07's Avatar
wills-07 is on a distinguished road
Default wheels
i have some rims i threw on, i would like to know what backspacing they have and what width they are, im guessing they are 4 or 4.5 bs and maybe 8 wide i could be very wrong, all i know is that my tires swell out a tiny bit unless thats just the tire type and they sit out of the fender about 2 inches.
Attached Thumbnails 15"x7" with 4" backspacing on 4x4 S10-jimmie-011rtrt.jpg
Old Oct 2, 2010 | 02:06 PM
bigjon1's Avatar
wills-07 those wheels look like they stick out as far as my cragars did. they were 15x7 with 4" backspacing. If your tires are 31's, then they will kind of bubble out a little. Which is alright by me
Old Oct 3, 2010 | 07:56 AM
S.Hafsmo's Avatar
Looks good.
How is it to drive with those wheels? any rubbing?
I have considered to go for maybe 8" wide wheels in the back, with the same backspacing as the 7" in the front to get the rear wheels a littlebit further out, But im not sure if the 4wd is very sensitive to different front/rear tire diameter?
Old Oct 3, 2010 | 08:40 AM
Mczuk's Avatar
Mczuk is on a distinguished road
Different width is ok but different diameter is bad, your transfercase won't be happy.
Old Oct 3, 2010 | 09:35 AM
wills-07's Avatar
Talking rims
i might get 30's later but rite now all i got is the p23575r15 and they just barely clear in the front,and i mean just barely!
im looking into new rims now though just want some black ones but the same size
Old Oct 4, 2010 | 01:22 PM
wills-07's Avatar
Originally Posted by S.Hafsmo
Looks good.
im sure if you drove over really big bumps you would hit the fenders but other than that no rubbing at all, with the back i just bought spacers to make them stick out even with the front tires, i would prefer a wider tire though. does that mean i would need to get a wider rim for the back
Old Oct 4, 2010 | 02:06 PM
wills-07's Avatar
Smile
i am about to buy new rims that are 15x7 and 4.5bs, i want my tires to stick out of the fenders alittle but did you have a problem with the rear tires not sticking out as far. i did and i put spacers on and im not a big fan of them, but now all my tires stick out the same and it looks good. i want to take the spacers off though, so i just wondering what size rims should i get for the back to make up for the spacers? can i just get the 15x7 and run a little wider of a tire or get 15x8 for the back or just get 4''bs for the back and 4.5 for the front? any help would be very apreciated , oh by the way i am just running p23575r15s on stock 4x4 height no lift.
