2000 Chevy blazer zr2 4x4 2 Dr
Old Mar 1, 2025 | 06:26 PM
Injun0222's Avatar
Injun0222 is on a distinguished road
Default 2000 Chevy blazer zr2 4x4 2 Dr
Need help, I need to know what is the widest tire I can put on my stock 15" rims / does not have a lift
Old Mar 1, 2025 | 10:32 PM
AJBert's Avatar
No more than 4 inches wider than the rim itself if I recall correctly. That would be 275 mm or 10.5 inches in common sized tires. However, plan on some rubbing unless you lift your vehicle and/or doing some trimming. Some tire shops may install wider tires, but most won't.
Old Apr 5, 2025 | 05:42 PM
daveca's Avatar
wide tires slowly kill wheel bearings. Avoid it.
Old Apr 7, 2025 | 10:16 AM
El_Beautor's Avatar
What AJBert said.
FYI, if you can find them, you should be able to put 255/70/15 tires on factory rims with factory suspension and not rub. I had that size on my 96 Blazer for a few years. They look a lot beefier than the factory 235's, but still fit with the stock suspension and are around the same height as the factory 235/75/15 that my Blazer called for.
CaRParts102
Apr 12, 2017 07:38 PM
Spectreblazer
Feb 13, 2010 04:59 PM
JIMBO(
Oct 20, 2009 09:12 AM
JIMBO(
Oct 20, 2009 08:04 AM
supercoop
Tires and Wheels
Oct 13, 2008 10:38 PM
