(2002 2wd 2door blazer )Will 255/70/15 on factory alloys fit w/ factory suspension?
Old Aug 8, 2015 | 01:10 AM
02Goldie_Loks's Avatar
02Goldie_Loks is on a distinguished road
Default (2002 2wd 2door blazer )Will 255/70/15 on factory alloys fit w/ factory suspension?
Hey everyone. I'm getting tires tomorrow and hopefully I can fit 255/70/15 under my blazer. Is has new gas adjust kyb's in the front with what looks like factory coils. Height is 32" from the bottom of the center of the fenders to the ground down the centerline of the wheel.
I'm using factory alloys.
Hope someone knows, because they don't make a 245/75/15 but a 255/70/15 is available.
Thanks!
Old Aug 8, 2015 | 07:10 AM
ohiofossil's Avatar
ohiofossil is on a distinguished road
I have 255/70/15 tires on S-10 Alloys on my 2002 4WD Blazer. The Front wheels BARELY rub on the bottom fender bolts on turns and in reverse, other than that they work just fine. They do not rub enough to damage the tire or the truck, just enough to be noisy
Old Aug 11, 2015 | 06:49 PM
El_Beautor's Avatar
I had 255/70/15 tires on my stock rims with stock suspension for 3 years. The only rubbing I had was on the sway bar, until I replaced the bushings and re-centered the sway bar. Then I never rubbed with those tires again.
Backdraft
Sep 1, 2014 09:08 AM
7designs
Lifting Tech
Jan 3, 2012 05:52 PM
bhesson
Tires and Wheels
May 1, 2006 10:44 PM
K5Carnage
Jun 6, 2005 08:22 PM
timetoblaze
Tires and Wheels
Apr 25, 2005 03:32 AM
