2010 Camaro steelies.......?
Haven't done the checking yet as to bolt pattern but the v6 lower end LS Camaro steel wheel that has the trim ring...or the ones ...anyone put em on a blazer yet? PICS PLEASE!!!
found this so i gather they'd fit
2010 Chevrolet Camaro (except SS)
Bolt Pattern: 5x120
Center Bore: 67
Hardware:14x1.50 Lug
Offset:
Front: 34mm
Rear: 38mm
These.....
![](https://t1.gstatic.com/images?q=tbn:ANd9GcQFPd13EQRuc-UXXexbGgRCS7ca6J5iuHyKMphFOF_m3da1PE8e)
Or better either of the 1 on the left?
Bolt Pattern: 5x120
Center Bore: 67
Offset:
Front: 34mm
Rear: 38mm
These.....
![](http://www.ls1tech.com/forums/attachments/gen-5-camaro-internal-engine-tech/142723d1218064846-poll-2010-camaro-stock-wheel-choices-camarowheels2010.jpg)
i have seen these up on craigslist maybe 2 times now due to some rich guy buying a camaro and slapping rims on it
no one has done it hear. for the price of those rims, you can get rims AND tires though.
if you find em cheap jump on them. they are sexy, but if i read you numbers right, the rear offset is 1.5" (or so) and the front is less
![Icon Denk](https://blazerforum.com/forum/images/smilies/icon_denk.gif)
If they were 15" I might give them a try. 18" just looks odd, unless you have a 2WD and plan on lowering it.
If I'm not mistaken, offset is the exact opposite of backspacing. I don't know the width of the rims, either. Just guessing at say 8.5 inches, this would give a back space of 6" on the rears and 6.2" up front, if my math is correct. If they are 9.5", that'll put the backspacing at 7" which might cause problems up front.
thanks for using a white 4 door
