22 inch cabo question(PLEASE HELP)
Old Mar 12, 2009 | 12:10 AM
97jim's Avatar
97jim is on a distinguished road
Default 22 inch cabo question(PLEASE HELP)
I have a 97 jimmy 4wd and i want to put my 22 inch cabo 113's on it..
The cabo's have a universal bolt pattern that doesnt fit my jimmy i was just wondering what size adapter would i need in order to make it fit.. http://www.wheelall.com/cabo-113.html the cabo's fit 1X120.65 mine is 1X120?? Please help me I just bout them and want them on ASAP!!
Oh and i have 265 35 22 tires..
Thanks
Old Mar 12, 2009 | 08:45 AM
5x120.65 == 5x4.75 which is what you have.
There is no mention of what back spacing the rim has though. But with those tires (265/35R22 == 29.3" OD), BS should not matter as much as if you were going with a larger diameter tire.
Old Mar 12, 2009 | 08:59 AM
97jim's Avatar
thanks alot swartlkk and excuse my ignorance on this this is my first set on rims but me and a buddy of mine tried putting 265 40 22 on it and it didnt fit..the bolts didnt line up it was of just a tab.. thats why i figured i would need an adaptor.. or do u think that tire was just to big and the 265 35 should fit
Old Mar 12, 2009 | 09:12 AM
A 265/40R22 is still only 30.3" OD tire so that should have fit as well.
When you say that the tire did not fit, what caused it not to fit? If it was the width (10.43"), then... That would not make a whole lot of sense seeing as how most rims have more backspacing than the factory rims which have 6" BS on a 4wd.
Old Mar 12, 2009 | 09:24 AM
97jim's Avatar
Im sorry if I am confusing you..I said "the tires didn't fit."I meant the bolts didn't line up properly... they where off a tap when trying to put the rim on
Old Mar 12, 2009 | 09:27 AM
Ok and this was with a 5x120.65 bolt pattern rim? If so, they should have lined up properly.
Old Mar 12, 2009 | 09:31 AM
97jim's Avatar
I thought the bolt pattern to 97 jimmy's blazers was 5X120 even..
I thought that may have made the difference the .65
Old Mar 12, 2009 | 09:39 AM
The bolt pattern all of the s-series vehicles is 5 on 4.75 inch (not metric).
4.75" == 120.65mm
120mm == 4.724" which is 0.036 short on the diameter. That should not have made a difference in getting the rim over the studs (depending on the hole size in the rim). But the webpage you linked to in your initial post does not list 5x120 as an available hole spacing... And just so you are aware, not all of those bolt patterns are available on the same rim. There would be nothing left to actually bolt to if they were. They are just listing what available bolt patterns can be machined into the rim.
Another popular bolt spacing is 5x4.5" or 5x114.3mm which is likely what you have. You need to determine what the pattern is.
Old Mar 12, 2009 | 09:44 AM
97jim's Avatar
It was probably just a bad install on our behalf thanks a mill... I'm taking it to a tire shop tomorrow to get new tires the 265 35's hopefully they can get it..
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
salvy
Nov 29, 2008 07:03 PM
rogggg1020
Nov 11, 2008 08:05 AM
