235/70/15 on a 98 2WD?
Old Oct 11, 2011 | 10:12 PM
Razgriz's Avatar
Razgriz is on a distinguished road
Default 235/70/15 on a 98 2WD?
Just got a 98 2WD that came with 235/70/15's on it instead of the 205/75/15 from the factory and I'm needing to replace one of the tires. Is it hurting anything by having the bigger size tires on it and should I replace them with what's on it right now, or go back to the factory size?
Old Oct 11, 2011 | 10:31 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
the size is perfectly fine
no it will not hurt anything having a little bigger tire
why would you want a smaller tire? even a 2wd needs bigger tires to fill the wheel wells
Old Oct 11, 2011 | 10:39 PM
Razgriz's Avatar
Just wondering if it screwed up the speedometer or anything. I really like to take care of my stuff.
Old Oct 11, 2011 | 11:14 PM
69chevelle's Avatar
69chevelle is on a distinguished road
It WILL change the speed you are going in relation to the speedometer!!!!! by 3% :P
from the factory they have a 10% margin of error, generally speaking the speedo will read faster then you are going so odds are it will be reading closer to your actual speed
just replace the tire(s) you need to replace
LTrain2112
Tires and Wheels
Jan 26, 2012 10:32 AM
zuhri
Tires and Wheels
21
Jun 2, 2010 10:54 PM
neurotox
Tires and Wheels
Apr 20, 2009 03:44 PM
bodean
Tires and Wheels
Oct 20, 2008 06:25 PM
1996BZR
Tires and Wheels
Mar 12, 2006 02:20 AM
