245/75/16 on 95 4wd
Old Oct 7, 2008 | 10:01 AM
dougivks's Avatar
dougivks is an unknown quantity at this point
Default 245/75/16 on 95 4wd
Will I be able to fit 245/75/16 on a stock height 4wd 95 blazer. actually mine seems to be about an inch higher than other stock height blazers i see. no idea why, but I know the front is turned up a bit more. The tires will be going on 16*8 camaro wheels.
forgot to mention that i currently have 235/75/15s on it with no problems. the 245's should only be 1.5 inches taller total.
Old Oct 7, 2008 | 01:34 PM
nj4x4blaze's Avatar
Default RE: 245/75/16 on 95 4wd
Your stock tire diameter is 28.9" and if you go with the 245/75/16 your new diameter will be 30.5". Overall it's be a 1.6" difference so it should clear with no problem. You "might" rub a little when making sharp turns.
Old Oct 7, 2008 | 01:44 PM
dougivks's Avatar
cool, I figured I'd just try one first so I didnt have to pay to mount all 4 if it didn't work.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
