2WD Wheels on a 4x4
Old Aug 21, 2013 | 02:04 PM
HotRodHearseGuy's Avatar
HotRodHearseGuy is on a distinguished road
Default 2WD Wheels on a 4x4
I've managed to either completely confuse myself or something. I'm looking at picking up at set of wheels for my '98 Blazer (Lil' Stinker). I know they were used on I believe the Xtreme S10 pickups for a couple of years. With everything planned for modifications, these wheels will help set the truck off nicely.
My question is, do I need a spacer/adapters and if so, how many and what thickness(es)??
Old Aug 21, 2013 | 02:50 PM
nunya's Avatar
nunya is on a distinguished road
I dot know about that wheel in particular but I personally had 15" 2wd wheels on mine (now my winter set) and the only reason I had/have spacers is on the rear due to the dumb narrower rear axle stance (for visual effect, they were/are not needed).
Old Aug 21, 2013 | 03:24 PM
ckroll98's Avatar
ckroll98 is on a distinguished road
I have 15" 2WD swirl wheels on my 2dr 4x4. No spacers. The backspacing on these wheels pushes the tire out a little past the fender. No issues with turning and may allow me to go to larger tires without a body lift.
Old Aug 21, 2013 | 03:39 PM
Jamaroon's Avatar
No spacers/adapters required. You might run into some clearance issues depending on what size tire you will be running.
Old Aug 21, 2013 | 08:51 PM
Thanks for the input guys! I really wasn't sure due to the front differential being more like a FWD car or minivan as opposed to the normal RWD style setup. If I do run spacers, it will most likely then to help bring things out more to make them look/appear correct.
Old Aug 21, 2013 | 08:59 PM
rexmburns's Avatar
Super Moderator
You will only need spacers on the rear to match the front as the 2wd rims will already give you about 2" of extra width.
Old Aug 22, 2013 | 10:35 AM
CraigSnedeker's Avatar
I learned the hard way that 4x4 Blazer rims don't fit in a 2wd haha.
Old Aug 22, 2013 | 09:46 PM
Thogert's Avatar
4x4 rims will fit, but that's when you need the spacers to get them to fit.
blazen_red_4x4
Tires and Wheels
32
Jun 26, 2014 11:00 AM
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
blazer206
Tires and Wheels
Feb 23, 2010 10:29 PM
bitbandit
Tires and Wheels
Feb 12, 2008 02:41 PM
juicy_jay_510
Feb 1, 2008 07:35 AM
