31 10.5 15
I just copied a post made by Jigg a long time ago into the Tech Articles (DIY) section. It has the steps, but none of the cautions. We will need to discuss modification of the article to include this in the DISCUSSION thread for the article.
will wheel spacers help me or hurt me with 15x10 rims. I believe the back spacing is 3 3/4.
*Combining Consecutive Posts*
is this even possible?
*EDIT by swartlkk* - Please use the EDIT feature to add additional information to your post if another member has yet to reply. Consecutive posting is prohibited by the rules of the forum.
blocks wont lift these trucks unless you have done a spring over axle conversion in which case fitting 31's would not be an issue at all, you need shackles to lift blocks will only lower it in stock configuration. Take the tbar keys back you wont gain anything just crank your stock keys 1.5" the new keys wont let you get any higher unless you want to be replacing cv's and ball joints constantly.
