33 baby
can i put 33 10.50 on my ZR2
RE: 33 baby
Not if your searching capabilities are anything to go by:D
RE: 33 baby
im 17 speak english
RE: 33 baby
ORIGINAL: WolfPack Not if your searching capabilities are anything to go by:D you cannot fit 33's without lifting it and or cutting away part of the fenders |
RE: 33 baby
2 inch body lift work?
RE: 33 baby
Your age has nothing to do with anything.
Before posting a new thread, you should use the search funtion to see if your question has already been answered. You might want to check out the forum Rules & FAQ, that would have saved you from double posting.. And you will probably still have to do some minor trimming to avoid rubbing even after the 2' BL. Nothing a slight t-bar adjustment might fix though. |
RE: 33 baby
I have 33x12.50 BFG MT's on my ZR2.
Here's my page with all of the modifications to my truck: Jigg's Blazer Basically, I have: 2" BL 2.25" Lift Shackles 1" Tbar crank Air Shocks Add A Leafs A bit of fender trimming You may have a more difficult time, depending on the specs of your wheels... do you know the width and backspacing of them? Or even the model? |
RE: 33 baby
ORIGINAL: Jigg I have 33x12.50 BFG MT's on my ZR2. Here's my page with all of the modifications to my truck: Jigg's Blazer Basically, I have: 2" BL 2.25" Lift Shackles 1" Tbar crank Air Shocks Add A Leafs A bit of fender trimming You may have a more difficult time, depending on the specs of your wheels... do you know the width and backspacing of them? Or even the model? |
RE: 33 baby
hey jigg what could i do to improve performance on my blazer its completly stock
RE: 33 baby
also where could i get a 2 inch body lift for cheap being 17 my budget is low making the payment for my 01 is bad enough
