33 baby
Old Feb 28, 2008 | 12:29 PM
Redmenhockey10's Avatar
Redmenhockey10 is an unknown quantity at this point
Default 33 baby
can i put 33 10.50 on my ZR2
Old Feb 28, 2008 | 12:51 PM
WolfPack's Avatar
Default RE: 33 baby
Not if your searching capabilities are anything to go by
Old Feb 28, 2008 | 12:58 PM
Default RE: 33 baby
im 17 speak english
Old Feb 28, 2008 | 01:07 PM
mdehoogh's Avatar
Default RE: 33 baby
ORIGINAL: WolfPack
HA!
you cannot fit 33's without lifting it and or cutting away part of the fenders
Old Feb 28, 2008 | 01:11 PM
Default RE: 33 baby
2 inch body lift work?
Old Feb 28, 2008 | 01:34 PM
WolfPack's Avatar
Default RE: 33 baby
Your age has nothing to do with anything.
Before posting a new thread, you should use the search funtion to see if your question has already been answered. You might want to check out the forum Rules & FAQ, that would have saved you from double posting..
And you will probably still have to do some minor trimming to avoid rubbing even after the 2' BL. Nothing a slight t-bar adjustment might fix though.
Old Feb 28, 2008 | 02:57 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: 33 baby
I have 33x12.50 BFG MT's on my ZR2.
Here's my page with all of the modifications to my truck:
Jigg's Blazer
Basically, I have:
2" BL
2.25" Lift Shackles
1" Tbar crank
Air Shocks
Add A Leafs
A bit of fender trimming
You may have a more difficult time, depending on the specs of your wheels... do you know the width and backspacing of them? Or even the model?
Old Feb 28, 2008 | 05:28 PM
mdehoogh's Avatar
Default RE: 33 baby
ORIGINAL: Jigg
Jigg's Blazer
Basically, I have:
2" BL
2.25" Lift Shackles
1" Tbar crank
Air Shocks
Add A Leafs
i didnt realize you had lift shackles and add-a-leafs. wouldn't that result in a very raked truck? especially with only 1" tbar crank. do the shocks lift it up at all?
Old Feb 28, 2008 | 06:22 PM
Default RE: 33 baby
hey jigg what could i do to improve performance on my blazer its completly stock
Old Feb 28, 2008 | 06:29 PM
Default RE: 33 baby
also where could i get a 2 inch body lift for cheap being 17 my budget is low making the payment for my 01 is bad enough
