33" tires
Old Jun 1, 2011 | 08:22 PM
blazeduphigh14's Avatar
blazeduphigh14 is on a distinguished road
Default 33" tires
Can somebody help me out? 2003 with a 2" suspension and 2" body lift can i fit 33x12.5x15? or do i have to stick with a 32,31?
Old Jun 1, 2011 | 08:42 PM
69chevelle's Avatar
69chevelle is on a distinguished road
31's I would say..
I got a 3" body 1.5" susp and had to trim a fair bit in the front to clear...
33"s I could get away with a 10.5 maybe but would rub the frame was to bad with a 12.5 (have a set to try so will update when I get time to test fit)
Keep in mind you will need to get a different offset wheel or you will be rubbing the frame pretty bad even with a 31... which will push your front tires past the fender a bit..
Old Jun 13, 2011 | 02:09 PM
TURBO's Avatar
TURBO is on a distinguished road
Chevelle, Pics?
Old Jun 13, 2011 | 09:35 PM
warthogdriver's Avatar
i have 9 inches total lift with 33x12.5 and i have rubbing....needed a minor fender trim even with all that lift.
Old Jun 13, 2011 | 10:57 PM
NVANZEE's Avatar
same here. Mine rub the back of the front fender and the front of the rear quarter. I also have 9in of lift with 33x12.5. My wheels have 4in backspacing
Old Jun 13, 2011 | 11:24 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
^^What they said^^
You could get away with 32's and a lot of trimming. But the backspacing would have to be about 5" on a 15x7 or 6" on a 15x8. At least that's my best guess.
Old Jun 13, 2011 | 11:28 PM
Rottidog's Avatar
3" BL & 1.5" TB twist & the 32 x 11 rub on the front at full deflection with fender & bumper trimming when turning. But I have aftermarket flares & mud flaps on the front as well, just to keep the chit from covering the front windows. Check out my garage to see pics if you like.
<edit> I'm running 15 x 10 rock crawlers.
Old Jun 14, 2011 | 05:24 PM
TURBO's Avatar
rob44.... tire dimensions? and what size lift?
Old Jun 14, 2011 | 07:07 PM
All detailed conveniently for you in his garage (vehicle link under his screen name).
Old Jun 14, 2011 | 10:32 PM
69chevelle's Avatar
check my garage, I wouldn't reccommend you trim as much as I did, I would just stick with 31's....
My wheels are 15X7 with a 4.5" backspacing
