37s ON STOCK CHEVY?? help!!!
Old Jul 15, 2011 | 02:37 AM
Blazerkid01's Avatar
Blazerkid01 is on a distinguished road
Default 37s ON STOCK CHEVY?? help!!!
Alright so this guy has a set of Nitto mud grappler 37x13.50r20s for sale for 800 peso's, idk how 37s fit on a stock chevy, i wana know if they will fit on my 98 i have 3in body lift. Any help or pictures would be awesome thanks.
Nice 20 inch rims and BIG tires
Old Jul 15, 2011 | 02:57 AM
RangerG's Avatar
Not a chance. Especially 13.5s. You wouldn't be able to turn, if they would even mount. Simply isn't enough fender clearance on these. The only thing I've seen something that big on would be like a ZR2 with a SAS swap and body lift on top of that...
Old Jul 15, 2011 | 04:14 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
With your setup you can probably get 33's to fit. Even thats pushing it.
Old Jul 15, 2011 | 04:52 AM
Thogert's Avatar
Here is an example of what 37s would look like on mine with 1 to 2 inches of suspension travel avalible. I don't have a body lift so a 3 in. would give you ~5 in. of travel on this pic.
Old Jul 15, 2011 | 01:40 PM
Mczuk's Avatar
Mczuk is on a distinguished road
I'm guessing since they are six lug they are for a fullsize? What year? Even if they would fit you would still have a problem turning them, which leads to lower gears etc. etc.etc.
Old Jul 16, 2011 | 09:59 AM
abig84's Avatar
Old Jul 16, 2011 | 11:06 AM
aneill75's Avatar
aneill75 is on a distinguished road
Originally Posted by abig84
Too funny.
Maybe the OP should check this out Looks like 37" rubber requires 9" of lift
START HERE - Lift Kit List
Originally Posted by nj4x4blaze
What tires will fit?
No lift or Torsion Bar tweak & 2" Rear Shackles
Torsion bar tweaking can gain you 1-1.5 inches. If you get more it means your torsion bars were sagging or low from the factory (typical with the Sport package).
205's (standard tire size)
235's (optional tire size)
30's should clear all but the ones with sagging torsion bars
31's should fit with minor trimming/reshaping, anything larger needs lift.
Tire Sizes with 2-3" of lift
31's should fit, if using stock wheels expect the tires to rub on the frame and sway bar at full lock
32's should fit with minor trimming
33's should fit with massive trimming
Tire sizes with 5-6" of lift
32's should easily clear, if using stock wheels expect the tires to rub on the frame and sway bar at full lock
33's should fit with minor trimming
35's may fit with massive trimming
Tire sizes with 7-8" of lift (With 2" Body Lift)
33's should fit easy
35's should require minor trimming with 8 inch wheels, more if 10 inch wheels are used
36's would require massive trimming to be done.
9" lift (SAS)
37" tires should fit easy
38.5" tires may fit with a body lift or trimming.
TIRE CALCULATOR SITE:
Tire size calculator
Old Jul 16, 2011 | 09:52 PM
abig84's Avatar
I couldn't imagine the front end taking those tires. I had a 85 with 33 12.50s on it. With a beat 2.8 and I was breaking cv joints like crazy
Old Jul 16, 2011 | 10:33 PM
aneill75's Avatar
Thus the SAS conversion
Old Jul 16, 2011 | 11:31 PM
Did anyone look at the pic, the guy has been running them for 50000 miles and hasnt had a problem, all he trimed has his front bumper and he had NO LIFT. Not saying its a good idea i personally thought he was crazy. Nice 20 inch rims and BIG tires
