74 K5 Wheel Upgrade
Old Mar 8, 2020 | 03:21 PM
Russtache's Avatar
Russtache is on a distinguished road
Default 74 K5 Wheel Upgrade
Time for wheels.…
I was running 15x 9 ish American Racing Wheels ... yeah 30 years old ... with 35 12.50 s.
As I price around for possible 17 inchers I’m running into some fear an uncertainty on fitment.
I get it .. the current wheels have about 4” backspace and they are right on the tie rod...
Most the 17 s I’m finding are 4.5 or more ... Rhino Shrapnel was one example ....
I think the added diameter allows for it to clear ...
I am wondering if anyone else has done a test fit .... which is obviously next .... or if there is some obvious reason I’m not going to find a suitable 17?
The wife says I could use a little more diameter.
Old Mar 8, 2020 | 07:01 PM
I'm pretty sure 17s would give you enough room to clear the TRE, but maybe this is an excuse for you to get 18s instead. 18s are like the new 15s these days.
Old Mar 8, 2020 | 07:38 PM
Russtache's Avatar
It’s not like I’ll be climbing Black Bear Pass with it ... but it will see offroad in Colorado .... I’m a little unclear what the max wheel / tire diameter ratio is to still maintain some rockability ... considering 35” rubber.
Old Mar 9, 2020 | 11:55 AM
I run 37s on 15" rims and the rims still get gouged by rocks. But if you don't do any crazy rock crawling and you don't air down too much, I think you'd be ok.
Old Mar 9, 2020 | 11:56 AM
Russtache's Avatar
Thanks for the advice.....!
Old Mar 16, 2020 | 11:16 AM
Russtache's Avatar
Well after some fun and games with the wrong offset getting ordered .... I did a test fit on this Black Rhino Shrapnel model.
It's a 9.5 width .... the -18 offset gives it a 4.54" backspace ... the old wheel had 4" ... but the extra diameter helped clear the tie rod ends.
I had trouble with the lug holes on the old wheels wallowing out, never had hub rings on them, not sure if that can relieve some stress .. of course that doesn't help me on the rear (drums).
Maybe I should spritz the brake shield with some fresh paint.
Old Mar 16, 2020 | 11:24 AM
Those look good. Post some more pictures when you get some tires on them.
Old Mar 16, 2020 | 03:39 PM
Looks good, are you going to add some body color to them? Or are they staying black?
Old Mar 25, 2020 | 02:21 PM
Russtache's Avatar
I think I'll keep 'em black haha. I gotta enough to do. I'll continue to post on the Build thread.
2001ZR2
Tires and Wheels
Nov 12, 2019 09:49 PM
RedmonFF
Tires and Wheels
May 5, 2014 02:57 PM
Clark Kent
Aug 20, 2013 06:22 AM
DetailersDomain
Detailing
Jun 11, 2012 11:44 AM
svtcobra94
Tires and Wheels
Sep 3, 2009 12:31 PM
