great! i just ordered me a set of cooper's discover atr
30/9.50/15's can't wait |
Nice pickup on the wheels i was looking for a good deal on the same ones but came across ar23"s in stead and went with them.
My truck has the road noise i think you are talking about and when i was changing out my front brakes i noticed when i trun the hub by hand on the driver side it felt a little rough but not loose. Do you think its just the wheel berings or do i need to change the hole hub? |
Originally Posted by BAM1369
(Post 387858)
My truck has the road noise i think you are talking about and when i was changing out my front brakes i noticed when i trun the hub by hand on the driver side it felt a little rough but not loose. Do you think its just the wheel berings or do i need to change the hole hub? here's what i did: I jacked up the front side. and with the wheels (bolted) i grab hold of the entire wheel and wiggled it up/down.. side to side.. I had a lot of play in both direction.. (driver side) the passenger side had no play.. I have an 4x4, IIRC 2wheel are different perhaps you can only change the "bearing" instead of the whole hub assembly.. the "guru's" can confirm this.. |
I dont have any play in mine, so im guessing its ok to assume its just the berings?
(Post 387865)
Originally Posted by chidevildog
(Post 387870)
it was bad cv.. not quite sure if it was the upper or the lower.. i'll send you the link if i find it..
Originally Posted by rob44_90
(Post 387893)
Do you mean it was a bad ball joint?? There are no upper or lower CVs, just axle CVs and a drive-shaft CV on our trucks.
