another one about wheels
Old Apr 6, 2009 | 07:38 PM
bclhaezveyr's Avatar
bclhaezveyr is on a distinguished road
Default another one about wheels
i'm knew to this site, so don't chew me out for this one. i have an 02 blazer 4dr. 4x4. i'm looking to put a 2" suspension lift and other modifications. i was looking at some 15x8 wheels that i like but the backspacing ond offset are way past stock. any suggestions?
Old Apr 6, 2009 | 08:08 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you want the 8" width try finding some zq8 rims from a blazer or s10 theyre 16x8 and have 6in backspacing so theyll stick out about 1.25" on each side(if i remeber correctly) or any other stock 2wd wheel from a blazer/s10 will give you a lil wider stance. btw what are the specs of the wheels ur looking at??
Old Apr 6, 2009 | 11:37 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Before...
After...
15x7's with 4 inch offest - Z85 suspension and no lift & no rubbing!
As you can see, it really turned the truck up a notch or two!
Old Apr 7, 2009 | 07:13 PM
the wheels i was looking at were 15x8 with i think 4.5" backspace and a +6.0mm offset. they were a cheapie cragar wheel. the soft 8's.
Old Apr 7, 2009 | 07:38 PM
mikeinwi's Avatar
if you go with a 15x7 with that backspacing youll be fine.
Old Apr 7, 2009 | 07:52 PM
thanks. i was also thinking bout just getting 4 matching spare 15x7 and painting them. sounds dumb but they don't look to bad in black. just need center caps. also anyone know where i can find a swing out spare tire carrier??
Old Apr 7, 2009 | 08:31 PM
mikeinwi's Avatar
a junkyard would prolly be the best place for the tire carrier, but it will require some hefty mods to get a 2dr swing out carrier to work on ur 4dr.
Old Apr 7, 2009 | 08:48 PM
thats what i figured. might just fab up my own design. or get a roof rack and put it on top like i've seen done so many times. what do u think bout the painted wheel idea ?
Old Apr 7, 2009 | 08:59 PM
bandidolenny's Avatar
The back spacing depends on how far you want the wheels to stick out. The tire carrier will require you to install bracing or steel backing to the inside of the sheetmetal where it mounts.
Old Apr 7, 2009 | 09:11 PM
mikeinwi's Avatar
if you take the time and properly prep the wheels it will turn out just fine. and as far as the idea, to each his own, if it works for you and you like it i say go for it.
