Backspace and tire questions.
Old Feb 6, 2010 | 05:41 PM
JoshM's Avatar
JoshM is on a distinguished road
Default Backspace and tire questions.
Yes I searched, but it seemed like each thread said something different.
I have a 2wd 4-door 1998 Jimmy. From my understanding the lug pattern is 5x4.75. That seems unanimous throughout the search results.
I read that the backspacing for 2nd Gen 2wd's range from 4" to 4.5", and that the stock wheel is 15x6.
What backspacing would I need for a 15x8 wheel? 5"-5." or so? I want them to sit nearly where stock is, maybe a little further out. Them being flush with the fenders don't bother me a bit, but I'd rather them not stick out from the fenders more than an inch.
What's the stock tire size? Is it 205/75?
Sorry for the long post.
Old Feb 6, 2010 | 06:00 PM
You will want to check your clearances before increasing the back spacing. If you were to go with a 15x8 rim, I would say you would want to stick with the stock 4.5" BS. I believe there are things that will interfere with the rim if you push the tire towards the frame more.
Old Feb 6, 2010 | 06:02 PM
JoshM's Avatar
Oh, so the less backspace the closer it is to the vehicle?
I'm use to judging wheels by offset, where the lower the offset the more the wheel sticks out. Thanks!
Old Feb 6, 2010 | 06:10 PM
The higher the back spacing the closer it is to the vehicle.
And, well, it all depends on what you call low. closer to zero on a negative offset rim will push the wheel out further. But being a negative offset, the lower (more negative) the number, the closer to the vehicle it will get. Just depends on how you look at it.
With back spacing, just remember that it is the measurement from the inside lip of the rim to the wheel mounting surface. If the number gets smaller, the rim is pushed out more. If it gets larger, it is sucked back in towards the center of the vehicle.
Old Feb 6, 2010 | 06:12 PM
JoshM's Avatar
So a 15x8 wheel with 4.5" backspacing will be "pushed out" 2" further than the stock 15x6?
Would a 15x8 Cragar with 4" backspacing cause issues?
Old Feb 6, 2010 | 06:20 PM
You got it.
That Cragar would stick out 2.5" further than stock so you will want to check your clearances with the outer edge of the tire while turning.
yellowdawg
Tires and Wheels
Feb 27, 2010 04:55 PM
winmag766
Tires and Wheels
Feb 15, 2009 02:08 PM
JIMBOO
Tires and Wheels
Nov 2, 2008 10:50 AM
fishinhunter12391
Tires and Wheels
Sep 19, 2008 10:57 AM
if6was9
Tires and Wheels
Mar 1, 2008 10:29 PM
