backspacing
i am saving up some money for some new wheels. since i have 30s on my jimmy and i was wanting 15X7 pro comp rock crawler 37 series wheels. the lagerest backspacing they have is 4.5 is that goina make my tires scrub on the fender?
jimmyboy |
RE: backspacing
I have procomp series 97 in 15x8 with 4.5 inches of backspace with 30x9.5 tires. They do rub sometimes at full lock when i go over a good size bump or something like that. They seem to rub pretty good when I'm going in reverse and I turn the wheels for some reason. It shouldnt be as bad with 15x7 rims I wouldnt think though. Here's a pic of mine just to show you how much they do stick out
http://i2.photobucket.com/albums/y34...iggermt003.jpg |
RE: backspacing
Yep, they will rub. Get yourself a body lift, or trim the fenders.
The difference in backspacing pushes the tires further out, thus hitting the fender when the tire turns, especially when flexing out. |
RE: backspacing
if i was to crank my tbars will they still scrub on the fender?
jimmyboy |
RE: backspacing
is offset and backspacing the same? if not what is offset?
jimmyboy |
RE: backspacing
I have 31/10.50 procomp x-terrian's on a 97 4 door. I have 2" body and t bar tweak. The tires are monted on stock rims, the tires rub behind the tires on the frame on full lock. when the wheels if half turned and i hit a bump the tires will rub the fender. Im gonna have to fender trim to have mine not rub, and get a new set of rims to get the tires away from the frame.
