backspacing
Old Nov 13, 2006 | 11:16 AM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default backspacing
i am saving up some money for some new wheels. since i have 30s on my jimmy and i was wanting 15X7 pro comp rock crawler 37 series wheels. the lagerest backspacing they have is 4.5 is that goina make my tires scrub on the fender?
jimmyboy
Old Nov 13, 2006 | 04:02 PM
Kellen's Avatar
Kellen is an unknown quantity at this point
Default RE: backspacing
I have procomp series 97 in 15x8 with 4.5 inches of backspace with 30x9.5 tires. They do rub sometimes at full lock when i go over a good size bump or something like that. They seem to rub pretty good when I'm going in reverse and I turn the wheels for some reason. It shouldnt be as bad with 15x7 rims I wouldnt think though. Here's a pic of mine just to show you how much they do stick out
Old Nov 14, 2006 | 12:14 AM
Hanr3's Avatar
Yep, they will rub. Get yourself a body lift, or trim the fenders.
The difference in backspacing pushes the tires further out, thus hitting the fender when the tire turns, especially when flexing out.
Old Nov 14, 2006 | 01:26 PM
jimmyboy's Avatar
if i was to crank my tbars will they still scrub on the fender?
jimmyboy
Old Nov 14, 2006 | 01:51 PM
jimmyboy's Avatar
is offset and backspacing the same? if not what is offset?
jimmyboy
Old Nov 14, 2006 | 04:08 PM
eslhockey92g's Avatar
eslhockey92g is an unknown quantity at this point
I have 31/10.50 procomp x-terrian's on a 97 4 door. I have 2" body and t bar tweak. The tires are monted on stock rims, the tires rub behind the tires on the frame on full lock. when the wheels if half turned and i hit a bump the tires will rub the fender. Im gonna have to fender trim to have mine not rub, and get a new set of rims to get the tires away from the frame.
ccajun4real
Tires and Wheels
Nov 4, 2007 05:16 PM
Idriveachevy
Tires and Wheels
Nov 1, 2007 08:17 PM
kankoon52
Lifting Tech
Jul 27, 2007 01:10 PM
dirtyjersey
Tires and Wheels
Dec 5, 2006 09:16 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
