Best Tire Size for 98 4x4 s10 Blazer with 6 inch suspension and 2 inch body lift
Old 11-12-2016 | 10:35 AM
98BlazerBadass's Avatar
98BlazerBadass is on a distinguished road
Default Best Tire Size for 98 4x4 s10 Blazer with 6 inch suspension and 2 inch body lift
What is the best size for my vehicle with a 6 inch suspension lift and 2 in body lift? I want an offset stance. Should I just spend the money to get offset rims or just buy spacers? Thank you
Old 11-16-2016 | 05:24 PM
Put the money into the wheels and tires, not spacers. Although I run spacers on my 04 purely for stance/looks, spacers should really only be used when that little bit of clearance is needed to put on a set of wheels that you may have gotten second hand. But if you're buying wheels new, just get the offset you need to begin with. Picking a wheel with a 2wd S10/Blazer offset will make them stick out a couple inches further than stock 4wd wheels, and for most that is enough.
As far as size, I'm sure with a total of 8" of extra body clearance, you could clear at least 33"s, 35"s MAYBE, but 36"+ may be pushing it as you'll probably start hitting front suspension components at full steering lock. BUT, I could be completely wrong, and someone feel free to correct me if I am. I rubbed with just 31's with a shackle and torsion bar lift... If you want to go much bigger, it's time to start looking at swapping in a solid front axle.
Keep in mind that with an original stock tire size of less than 29", jumping up to a 33" on stock gearing is going to turn it into a dog on the road... not that a 4.3 Blazer with 8" of lift is going to be a fast vehicle anyhow :P
Attached Thumbnails Best Tire Size for 98 4x4 s10 Blazer with 6 inch suspension and 2 inch body lift-20161016_124211.jpg
Old 11-16-2016 | 08:58 PM
Thank you! I ordered offset rims with 32's today. I figured I could clear 33's but going off of other images, I really liked the look of the 32's. I think I can go without speed haha!
Old 11-17-2016 | 04:23 AM
newguy's Avatar
To big of tires and you'll to start think about the tranny and axles also. Better to be safe
hypedave
Tires and Wheels
12-11-2013 10:05 AM
wlorton
Lifting Tech
16
12-26-2009 05:05 PM
blazerboy124
Suspension Tech
08-06-2007 10:17 AM
third2121
Suspension Tech
07-25-2005 02:23 PM
Quick Reply: Best Tire Size for 98 4x4 s10 Blazer with 6 inch suspension and 2 inch body lift
