bf at's
Old Jul 31, 2007 | 11:44 PM
mdehoogh's Avatar
Default bf at's
could i fit 31x10.5 BFG A/T'sonmy stock rims(15x7) with a 2" bodylift?
Old Aug 1, 2007 | 06:21 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: bf at's
Yes, they will fit on your stock rims.
No, they won't fit under your stock ride height.
I don't know if 2" body will eliminate the rubbing.
The problem is that the BFG AT's have a tread pattern that is rather square creating sharp corners. These corners will rub if you try to fit a 31" under your stock Blazer. Been there, tried that! Anyway, I'm not sure if a body lift will solve everything because you may still have rubbing issues inside your wheel well. I do know that 30" BFG AT's will fit and there are several people on this site with them already on. I have 31's but they're a calmer pattern.
Do you see how tight things are?
Maybe someone else tried the 2" body already and can be of more help.
Old Aug 1, 2007 | 11:24 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: bf at's
even with the BL some people still rub on parts of the fender and the anti-sway bar.... I think a 2"BL and a torsion crank will eliminate all rubbing...
Old Aug 1, 2007 | 11:36 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: bf at's
I agree with a_tack on this statement. I am planning on doing a 2" body lift and a 2" rear shackles and 1-1.5" tbar crank and should be able to get 31's to fit and maybe 32's.
-Lenny
