Big rim help
Old May 15, 2007 | 09:09 AM
bigbill23's Avatar
bigbill23 is an unknown quantity at this point
Default Big rim help
ok guys, im new to this forum belong to another that isnt too much help so hopefully you guys can help me out. I have an 02 4dr 4x4 blazer I wanna put at least 20's if not 22's on it. I know 20's i wont need any modification but how about 22's? Also i was under the impression that with 20's i needed a 9.5' offset but yet i found 20's with a 8.5' offset! will they work or should i stick with 9.5'?? and what kinda offset should i use with 22's? required i dont need any modification to fit them?! Any other pointers or mods you guys recommend will be greatly appreciated! Thanks guys!
Old May 15, 2007 | 09:58 AM
Default RE: Big rim help
I think you have rim width confused with offset or back spacing. Your factory rims are 15x7.5 with 6" of backspacing. You will want to stick with the 6" of backspacing when you move up in rim diameter and the width of the rim will depend on the width of the tire you want to run.
Also, the lower the profile of the tire, the closer the treadwidth and rim width will have to be to each other.
Old May 15, 2007 | 04:52 PM
viper4559's Avatar
viper4559 is an unknown quantity at this point
What is a good width to run if you have 18"-20"s with low pro's? This is for future reference......when I have money.
Old May 21, 2007 | 03:51 PM
bigbill23's Avatar
ok now what offset should i use for a 4dr 4x4??? i remember someone saying that they got a rwd offset and it didnt work with 4x4? do i need to worry about a 20x8.5 or 20x9.5?? and i cant find the backspace for these 2 particular rims i like!
TJnorcal
Suspension Tech
May 29, 2013 09:06 AM
evuldrporkchop
Mar 4, 2013 01:20 AM
xxdatricandudexx
Nov 27, 2008 07:54 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
