biggest tires on stock wheels
Old Mar 12, 2009 | 03:28 PM
shouser's Avatar
shouser is an unknown quantity at this point
Default biggest tires on stock wheels
hey guys im kinda new to this site so bear with me. i have a 1996 blazer with stock wheels and tires right now. this is a daily driver so i want to keep things cheap and still be able to hit some mild trails. i was wandering the biggest tires i could put on my stock wheels after putting a 2" body lift on? i was also wandering if putting 1.5" wheel spacers just on the rear would hurt anything. thanks for yall's help.
Old Apr 21, 2009 | 09:57 PM
lombard's Avatar
lombard is an unknown quantity at this point
I believe the 2" body lift will let you run 31x10.5 without any other mods. I'll leave the wheel spacer discussion for someone else.
Old Apr 21, 2009 | 11:59 PM
okvortec's Avatar
I'm assuming your Blazer is not a ZR2 model since I'm not sure they made them in 96'..
But as lombard said, 31"s are the biggest you'll want to go with a 2" lift. As a general rule of safety, I believe you don't want a tire to be anymore than 4" wider than the rim... Someone correct me if I'm wrong please. As far as backspacing, I wouldn't worry about it.
Old Apr 22, 2009 | 01:45 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you want a wider stance you could always throw some 2wd wheels on thatll get you about 1.5" wider on each side iirc, but if you wanna run spacers a 0.75" spacer on each side will even up the rear with the front.
matt4x4
Jan 6, 2015 03:59 PM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
Cavalier z24
Tires and Wheels
Jun 8, 2009 08:14 PM
darvo
Tires and Wheels
Nov 13, 2007 03:10 PM
Raider Fish
Tires and Wheels
Apr 4, 2005 02:38 PM
